network port vlan create
Create a virtual LAN (VLAN)
The network port vlan create
command attaches a VLAN to a network port on a specified node.
-node {<nodename>|local}
- Node-
The node to which the VLAN is to be attached.
You cannot attach a VLAN to a cluster port. - {
-vlan-name {<netport>|<ifgrp>}
- VLAN Name -
The name of the VLAN that is to be attached. This name should be a combination of the name of the port or interface group and the VLAN ID, with a hyphen between, such as "e1c-80".
-port {<netport>|<ifgrp>}
- Associated Network Port -
The network port to which the VLAN is to be attached.
-vlan-id <integer>
- Network Switch VLAN Identifier }-
The ID tag of the created VLAN.
This example shows how to create VLAN e1c-80 attached to network port e1c on node1.
cluster1::> network port vlan create -node node1 -vlan-name e1c-80
