system script start
PDF of this doc site
Creating your file...
Start logging all CLI I/O to session log
The system script start
command starts creating a record of your CLI session. The record is stored in a file. Use the system script show -this-session
yes
command to display files that are recording the current CLI session. Use the system script stop command to stop recording the current CLI session.
-filename <text>
- Filename to Log To-
Use this parameter to specify the file name to which the CLI session record is saved.
-size-limit {<integer>[KB|MB|GB|TB|PB]}
- Logfile Size Limit Max:2GB-
Use this parameter to specify the maximum size of the file that contains the CLI session record. When the file size reaches this limit, recording stops. The default file size limit is
1 MB
. The maximum file size limit is2 GB
The following example shows how to start creating a record of the CLI session in a file named sessionlog3
. The size limit of this file is 20 MB
cluster1::> system script start -filename sessionlog3 -size-limit 20MB
