volume snaplock show
Display SnapLock attributes of a SnapLock volume
The ` volume snaplock show ` command displays following information :
Vserver name
Volume name
SnapLock Type of the volume
Minimum retention period applicable of the volume
Default retention period applicable of the volume
Maximum retention period applicable of the volume
Autocommit period of the volume
Volume Append Mode attribute of the volume
Privileged Delete attribute of the volume
Litigation count on the volume
Volume expiry time of the volume
Volume ComplianceClock
SnapLock audit log volume
This command is applicable only for SnapLock volumes.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <vserver name>]- Vserver-
If this parameter is specified, the command displays information for all the SnapLock volumes that match the specified
-vservervalue. [-volume <volume name>]- Volume-
If this parameter is specified, the command displays information for the specified
-volumevalue. [-type {non-snaplock|compliance|enterprise}]- SnapLock Type-
If this parameter is specified, the command displays all the volumes that match the specified
-typevalue. [-minimum-retention-period {{<integer> seconds|minutes|hours|days|months|years} | infinite}]- Minimum Retention Period-
-minimum-retention-periodvalue. [-default-retention-period {{<integer> seconds|minutes|hours|days|months|years} | min | max | infinite}]- Default Retention Period-
-default-retention-periodvalue. [-maximum-retention-period {{<integer> seconds|minutes|hours|days|months|years} | infinite}]- Maximum Retention Period-
-maximum-retention-periodvalue. [-autocommit-period {{<integer> minutes|hours|days|months|years} | none}]- Autocommit Period-
-autocommit-periodvalue. [-is-volume-append-mode-enabled {true|false}]- Is Volume Append Mode Enabled-
-is-volume-append-mode-enabledvalue. [-privileged-delete {disabled|enabled|permanently-disabled}]- Privileged Delete-
-privileged-deletevalue. [-expiry-time <text>]- Expiry Time-
-expiry-timevalue. [-compliance-clock-time <text>]- ComplianceClock Time-
-compliance-clock-timevalue. [-litigation-count <integer>]- Litigation Count-
-litigation-countvalue. [-is-audit-log-volume {true|false}]- Is SnapLock Audit Log Volume-
-is-audit-log-volumevalue.
The following command shows summary of SnapLock volumes on a vserver:
cluster1::> volume snaplock show Vserver Volume SnapLock Type ComplianceClock Time ------------- --------------- ------------- ----------------------------------- vs1 vol_slc compliance Mon Jan 19 14:12:34 IST 2015 +05:30 vs1 vol_sle enterprise Mon Jan 19 14:12:34 IST 2015 +05:30 2 entries were displayed. cluster1::>
The following commands lists the complete SnapLock attributes of two given SnapLock volumes:
cluster1::> volume snaplock show -vserver vs1 -volume vol_slc
Vserver Name: vs1
Volume Name: vol_slc
SnapLock Type: compliance
Minimum Retention Period: 1 years
Default Retention Period: max
Maximum Retention Period: 30 years
Autocommit Period: 12 hours
Is Volume Append Mode Enabled: false
Privileged Delete: permanently-disabled
Expiry Time: Thu May 11 14:37:21 GMT 2017
ComplianceClock Time: Wed May 11 20:08:41 IST 2016 +05:30
Litigation Count: 0
Is SnapLock Audit Log Volume: false
cluster1::>
cluster1::> volume snaplock show -vserver vs1 -volume vol_sle
Vserver Name: vs1
Volume Name: vol_sle
SnapLock Type: enterprise
Minimum Retention Period: 6 months
Default Retention Period: min
Maximum Retention Period: infinite
Autocommit Period: none
Privileged Delete: enabled
Expiry Time: infinite
ComplianceClock Time: Wed May 11 20:08:44 IST 2016 +05:30
Litigation Count: 0
