system status show
PDF of this doc site
Creating your file...
Display System Status
The system status show
command displays information about the status of objects in Data ONTAP. You can limit output to specific types of information and specific status in Data ONTAP, or filter output by specific field values.
To see a list of values that are in use for a particular field, use the -fields
parameter of this command with the list of field names you wish to view.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-internal-name <text>]
- Internal Full Name-
Selects status of objects that match this parameter value.
[-name <text>]
- Name-
[-vserver-id <text>]
- Vserver ID-
[-cluster-id <text>]
- Cluster ID-
[-is-cluster-scope {true|false}]
- Cluster Scope-
[-status <text>]
- Status Value-
Use this parameter to display the status.
[-update-time <MM/DD/YYYY HH:MM:SS>]
- Update Time-
Use this parameter to display the status last update time.
The following example displays information about system status in ONTAP:
cluster1::> system status show Cluster:tfarrellnscluster-1 Node:tfarrell-vsim1 Hypervisor system name:vsimesxrtp060.gdl.englab.netapp.com Version:5.5.0 Cpu count:20 Cpu version:CPU Pkg/ID/Node: 0/0/0 Intel(R) Xeon(R) CPU E5-2680 v2 @ 2.80GH Cpu count (virtual):40 ONTAP guests:5 Total guests:7 Memory configured:255.9GB Memory used:52.08GB Physical Interface count:2 Storage controller:LSI Logic / Symbios Logic 2004 iMR ROMB Storage configured:20GB Virtual Interface count:3 Guest name:tfarrell_vsim_nsc1 Memory configured:16GB Cpu count:4 Virtual Interface:vmk0 adminStatus:up Mtu size:1500 operStatus:up speed:unlimited Virtual Interface:vmk1 adminStatus:up Mtu size:9000 operStatus:up speed:unlimited Virtual Interface:vmk2 adminStatus:up Mtu size:9000 operStatus:up speed:unlimited Physical NIC:vmnic0 adminStatus:up Mtu size:9000 operStatus:up speed:9.77GBps Physical NIC:vmnic1 adminStatus:up Mtu size:9000 operStatus:up speed:9.77GBps System up time:468:11:40 Traps: 1.3.6.1.4.1.6876.50.101.0:TRAPv1 SNMPv1 'public' enterprise=1.3.6.1.4.1.6876.4.1 agent_addr=10.226.10.220 generic_trap=6 specific_trap=4 time-stamp=604476800 [0]: 1.3.6.1.4.1.6876.50.101.0=INTEGER 4 [1]: 1.3.6.1.4.1.6876.50.102.0=OCTET STRING 78: 2f 76 6d 66 73 2f 76 6f 6c 75 6d 65 73 2f 32 34 64 35 38 39 61 65 2d 36 34 33 62 31 35 38 65 2f 76 73 69 6d 73 79 73 2f 76 73 69 6d 73 2f 76 73 69 6d 73 79 73 5f 76 73 69 6d 5f 76 73 69 6d 31 2f 44 61 74 61 4f 4e 54 41 50 2e 76 6d 78 [2]: 1.3.6.1.4.1.6876.2.1.1.2.2815=OCTET STRING 18: 76 73 69 6d 73 79 73 5f 76 73 69 6d 5f 76 73 69 6d 31 1.3.6.1.4.1.6876.50.101.0:TRAPv1 SNMPv1 'public' enterprise=1.3.6.1.4.1.6876.4.1 agent_addr=10.226.10.40 generic_trap=6 specific_trap=4 time-stamp=1683800 [0]: 1.3.6.1.4.1.6876.50.101.0=INTEGER 4 [1]: 1.3.6.1.4.1.6876.50.102.0=OCTET STRING 79: 2f 76 6d 66 73 2f 76 6f 6c 75 6d 65 73 2f 61 37 63 31 66 37 61 61 2d 39 65 39 63 63 34 61 30 2f 74 66 61 72 72 65 6c 6c 2f 76 73 69 6d 73 2f 74 66 61 72 72 65 6c 6c 5f 76 73 69 6d 5f 6e 73 63 31 2f 44 61 74 61 4f 4e 54 41 50 2e 76 6d 78 [2]: 1.3.6.1.4.1.6876.2.1.1.2.2093=OCTET STRING 18: 74 66 61 72 72 65 6c 6c 5f 76 73 69 6d 5f 6e 73 63 31 47 entries were displayed.
