system controller pcicerr threshold modify
Modify the Node PCIe error alert threshold
The system controller pcicerr threshold modify
command modifies node-wide PCIe correctable error threshold counts in the cluster.
[-pcie-cerr-threshold <integer>]
- Corr. Error Limit-
The PCIe error threshold count that would trigger an alert if exceeded.
[-nvram-bb-threshold <integer>]
- NVRAM Bad Block limit-
The NVRAM bad block threshold count that would trigger an alert if exceeded.
The example below displays the information about setting node-wide PCIe error threshold count in the cluster:
cluster1::> system controller threshold modify -pcie-cerr-threshold 100
