The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
vserver cifs home-directory search-path reorder
PDF of this doc site
Creating your file...
Your file is ready
Change the search path order used to find a match
The vserver cifs home-directory search-path reorder
command moves a search path to a new position in the search path order in the CIFS home directory configuration for the CIFS-enabled Vserver.
-vserver <vserver name>
- Vserver-
This parameter specifies the CIFS enabled Vserver for which you want to reorder searches.
-path <text>
- Path-
This parameter specifies the search path you want to move.
-to-position <integer>
- Target Position-
This parameter specifies the new position of the search path in the search path order.
The following example moves the search path /home1 to position 1 in the search path order for the CIFS home directory configuration on Vserver vs1.
cluster1::> vserver cifs home-directory search-path reorder -vserver vs1 -path /home1 -to-position 1
