network ndp neighbor show
PDF of this doc site
Creating your file...
Display static NDP neighbor entries
The network ndp neighbor show
command displays a group of static Neighbor Discovery Protocol (NDP) neighbors within one or more Vservers. You can view static NDP neighbors within specified Vservers, neighbors with specified IPv6 address, and neighbors with specified MAC address.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-vserver <vserver name>]
- Vserver Name (privilege: advanced)-
Displays the static NDP neighbors that have the specified Vserver as their origin.
[-neighbor <IP Address>]
- Neighbor Address (privilege: advanced)-
Displays the static NDP neighbors that have the specified IPv6 address.
[-mac-address <MAC Address>]
- MAC Address (privilege: advanced)-
Displays the static NDP neighbors that have the specified MAC address.
The following example displays all of the static NDP neighbors configured on Vserver vs0.
cluster1::*> network ndp neighbor show -vserver vs0 Vserver Neighbor MAC Address ------------------ ------------------------ ------------------- vs0 10:10::10 04:04:04:04:04:04 20:20::20 01:01:01:01:01:01 2 entries were displayed.
