ONTAP commands
vserver fcp wwn blacklist show
Displays the blacklisted WWNs
This command displays WWNs that have been blacklisted from re-use.
A blacklisted WWN is a WWN that is prohibited for use as either a fiber channel protocol service WWNN or a fiber channel data LIF WWPN.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-wwn <text>] - World Wide Name (privilege: advanced)
Selects the blacklisted WWNs that match the parameter value.
[-vserver <Vserver Name>] - Vserver Name (privilege: advanced)
Selects the blacklisted WWNs that were previously assigned to the Vserver(s) that match the parameter value.
cluster1::> vserver fcp wwn blacklist show
        WWN                     Vserver
        01:02:03:04:05:06:07:08 vs1
        01:02:03:04:05:06:07:09 vs1
        2 entries were displayed.
Displays the blacklisted WWNs.
