The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
system node image show-update-progress
PDF of this doc site
Creating your file...
Your file is ready
Show progress information for a currently running update
The system node image show-update-progress
command displays the progress of a software-image update initiated by using the system node image update command. The command displays progress until the update completes; you can also interrupt it by pressing Ctrl-C.
-node {<nodename>|local}
- Node (privilege: advanced)-
This optionally specifies the name of a node whose image-update progress is to be displayed.
[-follow <true>]
- Follow the Progress in the Foreground (privilege: advanced)-
Do use not use background processing for this command. If you do not use this parameter, the value is
true
The following example displays image-update progress:
node::> system node image show-update-progress ERROR: command failed: There is no update/install in progress
