event notification delete
Delete event notifications
The event notification delete command deletes an existing event notification.
-ID <integer> - Event Notification ID
Use this parameter to specify the ID of the notification to be deleted.
The following example shows the deletion of event notification with ID 1:
cluster1::> event notification show
ID     Filter Name       Destinations
1      filter1           email_dest, syslog_dest, snmp-traphost
cluster1::> event notification delete -ID 1
This table is currently empty.
