vserver cifs users-and-groups local-user show-membership
Display local users' membership information
The vserver cifs users-and-groups local-user show-membership command displays the membership of local users.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <vserver name>]- Vserver-
If this parameter is specified, the command displays local user membership information for local users that are associated with the specified Vserver.
[-user-name <CIFS name>]- User Name-
If this parameter is specified, the command displays local user membership information for a local user that matches the specified user name.
[-membership <CIFS name>,…]- Local Group That This User is a Member of-
If this parameter is specified, the command displays local user membership information for the local group of which this local user is a member.
The following example displays the membership information of all local users; user "CIFS_SERVER\Administrator" is a member of "BUILTIN\Administrators" group, and "CIFS_SERVER\u1" is a member of "CIFS_SERVER\g1" group.
cluster1::> vserver cifs users-and-groups local-user show-membership
Vserver User Name Membership
vs1 CIFS_SERVER\Administrator BUILTIN\Administrators
CIFS_SERVER\u1 CIFS_SERVER\g1
2 entries were displayed.
