vserver check lif-multitenancy show-results
Show the results of the latest multitenancy network run
You can view detailed information about the latest completed run, or the run for a Vserver.
Vserver - name of vserver run was for
Severity - severity of the message which is failure, warning, or info.
Failures are problems that need fixed. Warnings are potential
problems that may need to be fixed. Values are "failure", "warning" or "info". -
Service - name of service that is being checked for connectivity
Address - address of server configured for the above service that is being
checked for connectivity. -
LIF - the LIF a successful connectivity check to the above server was made from
Connected - true of there is connectivity, false if there is not
Status - additional information useful for resolving issues
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <vserver>]- Vserver-
Selects the messages matching the specified Vserver
[-severity <text>]- Severity-
Selects the messages matching the specified severity of failure, warning, and info.
[-service <text>]- Service Name-
Selects the messages matching the specified service.
[-address <text>]- Address of Server-
Selects the messages matching the specified address.
[-lif <lif-name>]- Logical Interface-
Selects the messages matching the specified LIF.
[-connected {yes|no}]- Vserver Connectivity-
Selects the messages matching the specified connectivity.
[-status <text>]- Additional Information-
Selects the messages matching the specified search criteria.
Runs that are successful will not have any content.
cluster1::> vserver check lif-multitenancy show-results -vserver vs0
This table is currently empty.
Runs that fail display each failure that needs to be fixed.
Network Logical
Vserver Severity Service Address Interface Connected Status
vs0
warning - - vs0_lif1 - operationally down
warning - - vs0_lif2 - operationally down
failure DNS 10.98.200.20
- no cache
failure NIS domain 10.98.13.53 - no cache
4 entries were displayed.
