security certificate ca-issued revoke
Revoke a Digital Certificate
This command revokes a digital certificate signed by a Self-Signed Root CA.
-vserver <Vserver Name>- Vserver-
This specifies the name of the Vserver on which the certificate is stored.
-serial <text>- Serial Number of Certificate-
This specifies the serial number of the certificate.
-ca <text>- Certificate Authority-
This specifies the name of the Certificate Authority whose certificate will be revoked.
-ca-serial <text>- Serial Number of CA Certificate-
This specifies the serial number of Certificate Authority.
[-common-name <FQDN or Custom Common Name>]- FQDN or Custom Common Name-
This specifies a fully qualified domain name (FQDN) or custom common name or the name of a person. This field is optional if ca-serial is specified.
This example revokes a signed digital certificate for a Vserver named vs0 with serial as 4F5A2DF2 for a Certificate Authority certificate that has a ca of www.ca.com and a ca-serial of 4F4EB629.
cluster1::> security certificate ca-issued revoke -vserver vs0 -serial 4F5A2DF2 -ca `_www.ca.com_` -ca-serial 4F4EB629
