vserver start
PDF of this doc site
Creating your file...
Start a Vserver
The vserver start
command starts data access on a Vserver.
-vserver <vserver>
- Vserver-
This specifies the name of the Vserver on which the data access is to be started. This operation is only supported on a data Vserver.
The name must be of 47 characters length or less. [-foreground {true|false}]
- Foreground Process-
This specifies if the
vserver start
command should be executed in the foreground or background. If you do not enter this parameter, it is set totrue
, and thevserver start
command is executed in the foreground. [-force <true>]
- Force Vserver Start-
In case of a MetroCluster configuration or Vserver disaster recovery, by using this parameter you can start the Vserver that is either locked (which prevents any configuration changes) or its partner Vserver is operationally running. If you do not enter this parameter, it is set to false.
The following example starts data access on Vserver vs0.example.com
in the background.
cluster1::> vserver start -vserver vs0.example.com -foreground false
