cluster log-forwarding create
Create a log forwarding destination
The cluster log-forwarding create
command creates log forwarding destinations for remote logging.
-destination <Remote InetAddress>
- Destination Host-
Host name or IPv4 or IPv6 address of the server to forward the logs to.
[-port <integer>]
- Destination Port-
The port that the destination server listen on.
[-protocol {udp-unencrypted|tcp-unencrypted|tcp-encrypted}]
- Log Forwarding Protocol-
The protocols are used for sending messages to the destination. The protocols can be one of the following values:
_ udp-unencrypted _
- User Datagram Protocol with no security -
_ tcp-unencrypted _
- Transmission Control Protocol with no security -
_ tcp-encrypted _
- Transmission Control Protocol with Transport Layer Security (TLS)
[-verify-server {true|false}]
- Verify Destination Server Identity-
When this parameter is set to
true
, the identity of the log forwarding destination is verified by validating its certificate. The value can be set totrue
only when thetcp-encrypted
value is selected in the protocol field. When this value istrue
the remote server might be validated by OCSP. The OCSP validation for cluster logs is controlled with the security config ocsp enable -app audit_log and security config ocsp disable -app audit_log . [-facility <Syslog Facility>]
- Syslog Facility-
The syslog facility to use for the forwarded logs.
[-force <true>]
- Skip the Connectivity Test-
Normally, the
command checks that the destination is reachable via an ICMP ping, and fails if it is not reachable. Setting this value totrue
bypasses the ping check so that the destination can be configured when it is unreachable.
This example causes audit logs to be forwarded to a server at address 192.168.0.1, port 514 with USER facility.
cluster1::> cluster log-forwarding create -destination 192.168.0.1 -port 514 -facility user
