A newer release of this product is available. system node virtual-machine disk-object-store create 08/29/2024 Contributors Suggest changes Provide feedback PDFs PDF of this doc site application commands application provisioning commands autobalance commands autobalance aggregate commands cluster commands cluster contact-info commands cluster date commands cluster ha commands cluster identity commands cluster image commands cluster kernel-service commands cluster log-forwarding commands cluster peer commands cluster quorum-service commands cluster ring commands cluster statistics commands cluster time-service commands event commands event catalog commands event config commands event destination commands event filter commands event log commands event mailhistory commands event notification commands event route commands event snmphistory commands event status commands job commands job history commands job initstate commands job private commands job schedule commands lun commands lun bind commands lun copy commands lun igroup commands lun import commands lun mapping commands lun move commands lun persistent-reservation commands lun portset commands lun transition commands metrocluster commands metrocluster check commands metrocluster config-replication commands metrocluster configuration-settings commands metrocluster interconnect commands metrocluster node commands
