system chassis show
PDF of this doc site
Creating your file...
Display all the chassis in the cluster
The system chassis show
command displays information about all the chassis in the cluster. By default, the command displays the following information about all the chassis in the cluster:
Chassis ID
Status
List of nodes in the chassis
To display more details, use the -instance parameter.
[-fields <fieldname>,…]
Selects the fields that you specify.
[-instance ]
Displays detailed information about all the chassis in the cluster.
[-chassis-id <text>]
- Chassis ID-
Selects information about the specified chassis.
[-member-nodes {<nodename>|local}]
- List of Nodes in the Chassis-
Selects information about the chassis with the specified member node list.
[-num-nodes <integer>]
- Number of Nodes in the Chassis-
Selects information about the chassis with the specified number of nodes.
[-status {ok|ok-with-suppressed|degraded|unreachable|unknown}]
- Status-
Selects information about the chassis with the specified status.
The following example displays information about all the chassis in the cluster:
cluster1::> system chassis show Chassis ID Status List of Nodes -------------------------- --------------- ---------------------------------- 4591227214 ok node1,node2 4591227000 ok node1,node2
The following example displays detailed information about a specific chassis:
cluster1::> system chassis show -chassis-id 4591227214 -instance Chassis ID: 4591227214 List of Nodes in the Chassis: node1,node2 Number of Nodes in the Chassis: 2 Status: ok
