system node virtual-machine disk-object-store show
Display the list of object store configurations
The system node virtual-machine disk-object-store show command displays the list of object store containers that contain each node's disks.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-node <nodename>]- ONTAP Node Name (privilege: advanced)-
Represents the name of the ONTAP node for which information is to be displayed. If this parameter is not specified, the command displays information about all nodes in the cluster.
[-object-store-name <object store name>]- ONTAP Name for this Object Store Config (privilege: advanced)-
Selects object store configurations with the specified name.
[-server <text>]- Fully Qualified Domain Name of the Object Store Server (privilege: advanced)-
Selects containers on the specified server.
[-port <integer>]- Port Number of the Object Store (privilege: advanced)-
Selects containers attached on the specified port.
[-container-name <text>]- Container Name (privilege: advanced)-
Selects containers with the specified name.
[-azure-account <text>]- Azure Storage Account (privilege: advanced)-
Selects containers in the specified Azure storage account.
[-alive {true|false}]- Is Server Alive (privilege: advanced)-
Selects containers based on their aliveness state, as seen from the ONTAP node.
The following example displays the list of containers for each node in the cluster.
cluster1::*> system node virtual-machine disk-object-store show
Object Store
Node Name Azure Storage Account Container Name Alive
node1
objstore1 storageaccount1 container1 true
node2
2 entries were displayed.
