vserver nfs kerberos realm show
Display Kerberos realm configurations
The vserver nfs kerberos realm show command displays information about Kerberos realm configurations. The command output depends on the parameters specified with the command. If you do not specify any parameters, the command displays the following information about all Kerberos realm configurations:
  • Vserver
  • Kerberos realm name
  • Active Directory server name
  • Kerberos Distribution Center (KDC) vendor
  • KDC IP address
  • The permitted encryption types
{ [-fields <fieldname>,…​]
| [-instance ] }
[-vserver <vserver name>] - Vserver
If you specify this parameter, the command displays information only about the Kerberos realm configurations for the specified Vserver.
[-realm <text>] - Kerberos Realm
If you specify this parameter, the command displays information only about the Kerberos realm configurations that use the specified Kerberos realm.
[-kdc-vendor <Kerberos Key Distribution Center (KDC) Vendor>] - KDC Vendor
If you specify this parameter, the command displays information only about the Kerberos realm configurations that use the specified KDC vendor.
[-kdc-ip <IP Address>] - KDC IP Address
If you specify this parameter, the command displays information only about the Kerberos realm configurations that use the specified KDC IP address.
[-kdc-port <integer>] - KDC Port
If you specify this parameter, the command displays information only about the Kerberos realm configurations that use the specified KDC port number.
[-clock-skew <integer>] - Clock Skew
If you specify this parameter, the command displays information only about the Kerberos realm configurations that use the specified clock skew.
[-adserver-name <text>] - Active Directory Server Name
If you specify this parameter, the command displays information only about the Kerberos realm configurations that use the Active Directory server that has the specified name.
[-adserver-ip <IP Address>] - Active Directory Server IP Address
If you specify this parameter, the command displays information only about the Kerberos realm configurations that use the Active Directory server that has the specified IP address.
[-comment <text>] - Comment
If you specify this parameter, the command displays information only about the Kerberos realm configurations that match the specified comment text.
[-adminserver-ip <IP Address>] - Admin Server IP Address
If you specify this parameter, the command displays information only about the Kerberos realm configurations that use the specified administrative-server IP address.
[-adminserver-port <integer>] - Admin Server Port
If you specify this parameter, the command displays information only about the Kerberos realm configurations that use the specified administrative-server port number.
[-passwordserver-ip <IP Address>] - Password Server IP Address
If you specify this parameter, the command displays information only about the Kerberos realm configurations that use the specified password-server IP address.
[-passwordserver-port <integer>] - Password Server Port
If you specify this parameter, the command displays information only about the Kerberos realm configurations that use the specified password-server port number.
[-permitted-enc-types <NFS Kerberos Encryption Type>,…​] - Permitted Encryption Types
If you specify this parameter, the command displays information only about the Kerberos realm configuration that match the specified encryption types.
The following example displays information about all Kerberos realm configurations:
cluster1::> vserver nfs kerberos realm show
Kerberos                 Active Directory KDC        KDC
Vserver  Realm                    Server           Vendor     IP Address
AUTH     SEC.EXAMPLE.COM          AUTH.SEC.EXAMPLE.COM
                                                   Microsoft  192.0.2.170
