ONTAP commands
security login rest-role delete
Delete an access REST control role
The security login rest-role delete command deletes an access-control role.
-vserver <Vserver Name> - Vserver
This optionally specifies the Vserver name associated with the role.
-role <text> - Role Name
This specifies the role that is to be deleted.
-api <text> - api path
This specifies the api to which the role has access.
The following command deletes an access-control role with the role name readonly and the api "/api/storage/volume" for Vserver vs.example.com.
cluster1::> security login rest-role delete -role readonly -api /api/storage/volume -vserver vs.example.com
