The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
snaplock compliance-clock ntp show
PDF of this doc site
Creating your file...
Your file is ready
Display SnapLock ComplianceClock synchronization setting
The ` snaplock compliance-clock ntp show ` command will display ComplianceClock synchronization setting. It will display the following information:
is-sync-enabled - Displays if the option to synchronize the ComplianceClock with system time has been enabled or not.
cluster1::> snaplock compliance-clock ntp show Enable clock sync to NTP system time: true
