vserver audit prepare-to-downgrade
Restore the Audit configuration to Earlier Release of Data ONTAP
The vserver audit prepare-to-downgrade command restores the Audit configurations for ONTAP based on the input parameter disable-feature-set.
- -disable-feature-set <downgrade version>- Data ONTAP Version (privilege: advanced)
This parameter specifies the ONTAP version that introduced the new Audit features and needs to be removed. The value can be one of the following: -
9.0.0 - Disables the Audit features introduced in the ONTAP release 9.0.0. The following events are removed from the eventlist:
File share event. The corresponding parameter value is file-share.
Audit policy change event. The corresponding parameter value is audit-policy-change.
Local user account management event. The corresponding parameter value is user-account.
Local security group management event. The corresponding parameter value is security-group.
Authorization policy change event. The corresponding parameter value is authorization-policy-change.
cluster1::*> vserver audit prepare-to-downgrade -disable-feature-set 9.0.0
 PDFs
PDFs
