vserver fcp topology show
Show FCP topology interconnect elements
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-vserver <Vserver Name>]
- Vserver-
Use this parameter to select the interconnect elements for the specified Vservers.
[-lif <text>]
- LIF Name-
Use this parameter to select the interconnect elements for the specified FCP LIFs.
[-domain-id <integer>]
- Domain Identifier-
Use this parameter to select the interconnect elements with the specified domain identifier
[-logical-name <text>]
- Logical Name-
Use this parameter to select the interconnect elements with the specified logical name
[-vendor <text>]
- Vendor-
Use this parameter to select the interconnect elements with the specified vendor
[-release <text>]
- Release-
Use this parameter to select the interconnect elements with the specified release
[-wwn <text>]
- World Wide Name-
Use this parameter to select the interconnect elements with the specified World Wide Name
[-port-count <integer>]
- Port Count-
Use this parameter to select the interconnect elements with the specified port count
cluster1::> vserver fcp topology show Domain Logical Port Vserver Lif Name Id Name WWN Count ------- -------------- ------ ------------------- ---------------------- ----- vs1 lif1 98 ssan-fc0e-fit-01 20:05:00:05:73:bd:a3:01 15 99 ssan-fc0e-d38 20:05:8c:60:4f:04:f1:01 11 112 ssan-fc0e-5 20:05:00:0d:ec:ca:0b:41 19 119 ssan-fc0e-core-a 20:05:54:7f:ee:02:c1:01 18 159 ssan-fc0e-7 20:05:00:05:9b:24:6e:c1 38 169 sdev-fc0e-gg26 20:05:54:7f:ee:31:06:81 53 174 ssan-fc0e-d46 20:05:00:05:9b:7d:f8:01 16 177 ssan-fc0e-e49 20:05:54:7f:ee:ef:1c:81 19 180 ssan-fc0e-d40 20:05:00:05:9b:79:a3:c1 20 vs1 lif2 229 ssan-fc0e-6 20:05:00:05:73:c8:8f:01 33 233 ssan-fc0e-e45 20:05:54:7f:ee:a0:67:01 8 11 entries were displayed.
The example above show FCP topology interconnect information for the cluster.
