lun transition show
PDF of this doc site
Creating your file...
Display the status of LUN transition processing
The lun transition show
command displays information about the LUN transition processing status of volumes. If no parameters are specified, the command displays the following information about all volumes:
Vserver name
Volume name
Transition status
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-vserver <Vserver Name>]
- Vserver Name (privilege: advanced)-
Selects the volumes in the specified Vserver.
[-volume <volume name>]
- Volume Name (privilege: advanced)-
Selects the volumes with the specified name.
[-status {none|complete|failed|active}]
- Transition Status (privilege: advanced)-
Selects the volumes that match the specified transition status. The possible status values are:
active
- The volume is in an active SnapMirror transition relationship and not yet transitioned. -
complete
- LUN transition has completed for the volume. -
failed
- LUN transition has failed for the volume. -
none
- The volume did not contain LUNs to transition from Data ONTAP 7-Mode.
[-vserver-uuid <UUID>]
- Vserver UUID (privilege: advanced)-
Selects the volumes in the Vserver that matches the specified UUID.
[-node <nodename>]
- Filer ID (privilege: advanced)-
Selects the volumes that match the specified node.
The following example displays LUN transition information for all volumes in a Vserver named vs1
cluster1::*> lun transition show -vserver vs1 Vserver Volume Transition Status -------------------- ------------------ ----------------- vs1 vol0 none vol1 complete vol2 failed vol3 active 4 entries were displayed.
