snaplock legal-hold dump-files
Dump list of files under legal-hold to specified output path.
The snaplock legal-hold dump-files is used to dump the list of files under legal-hold for a given vserver, volume and litigation to an auto-generated file in the user specified path. Only a user with security login role vsadmin-snaplock is allowed to perform this operation.
-vserver <vserver name> - Vserver Name
Specifies the name of the Vserver for which the list of files under legal-hold is to be dumped.
-litigation-name <text> - Litigation Name
Specifies the name of the litigation for which the list of files under legal-hold is to be dumped.
-volume <volume name> - Volume Name
Specifies the name of the SnapLock compliance volume for which the list of files under legal-hold is to be dumped.
-output-volume <volume name> - Output Volume Name
Specifies the name of the output volume containing the output directory path where the list of files under legal-hold is to be dumped. The output volume must be a regular read-write volume.
-output-directory-path <text> - Path Relative to Output Volume Root
Specifies the output directory path relative to the output volume root, where the list of files under legal-hold is to be dumped. The output directory path should be of the form "/directory-path". If output needs to be dumped on the volume root, specify the path as "/".
The following example starts a legal-hold dump-files operation:
vs1::> snaplock legal-hold dump-files -volume vol1_slc -litigation-name lit1 -output-volume vol1 -output-directory-path /d1
            SnapLock legal-hold dump-files operation is queued. Run "snaplock legal-hold show -operation-id 16842754 -instance" to view the operation status.
            vs1::>
