event notification show
Display event notifications
The event notification show command is used to display the list of existing event notifications.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-ID <integer>]- Event Notification ID-
Use this parameter to display the detailed information about the notification ID you specify.
[-filter-name <text>]- Event Filter Name-
Use this parameter to display event notifications that use the filter-name you specify.
[-destinations <text>,…]- List of Event Notification Destinations-
Use this parameter to display event notifications that use the destinations you specify.
The following example displays the event notification:
cluster1::> event notification show ID Filter Name Destinations ----- ---------------- ----------------- 1 filter1 email_dest, syslog_dest, snmp-traphost
