system smtape break
Make a restored volume read-write
This command breaks the relationship between the tape backup of a volume and a restored volume, changing the restored volume from read-only to read/write.
-vserver <vserver name> - Vserver Name
Use this parameter to specify the Vserver name on which the volume is located. You need not specify this parameter if only one cluster Vserver exists.
-volume <volume name> - Volume Name
Use this parameter to specify the name of the read-only volume that needs to be made read/writeable after a restore.
Make the read-only volume datavol on Vserver vserver0 writeable after a restore.
cluster1::> system smtape break -vserver vserver0 -volume datavol
 [Job 84] Job succeeded: SnapMirror Break Succeeded
