system ha interconnect link on
Turn on the interconnect link
The system ha interconnect link on
command turns on the specified link on the high-availability interconnect device. For the nodes in the cluster with two external high-availability interconnect links, you must specify the link number (0-based) to turn on the specified link. For the nodes in the cluster with interconnect links over the backplane, you must specify the link number 1 to turn on the link.
-node <nodename>
- Node-
This mandatory parameter specifies the node on which the interconnect link is to be turned on. The value "local" specifies the current node.
-link {0|1}
- Link-
This mandatory parameter specifies the interconnect link number (0-based) to turn on.
The following example displays output of the command on the nodes with a single interconnect link or nodes with interconnect links over the backplane:
cluster1::*> system ha interconnect link on -node ic-f3250-02 -link 0 Error: command failed: Invalid link value 0. Specify 1. cluster1::*> system ha interconnect link on -node ic-f3250-02 -link 1
The following example displays output of the command on the nodes with two interconnect links connected externally:
cluster1::*> system ha interconnect link on -node ic-f3250-02 -link 0 cluster1::*> system ha interconnect link on -node ic-f3250-02 -link 1
