storage aggregate encryption show-key-id
PDF of this doc site
Creating your file...
Display encrypted aggregate information
The storage aggregate encryption show-key-id
command displays the key IDs of all NAE (NetApp Aggregate Encryption) aggregates.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-aggregate <text>]
- Aggregate-
If this parameter is specified, the command displays information only about the specific NAE (NetApp Aggregate Encryption) aggregate.
[-aggrID <UUID>]
- Aggregate UUID-
If this parameter is specified, the command displays the key ID of the specified NAE (NetApp Aggregate Encryption) aggregate ID.
[-keyid-index-zero <text>,…]
- 0th Index Keyid-
If this parameter is specified, the command displays the 0th index key ID of NAE (NetApp Aggregate Encryption) aggregates.
