ONTAP commands
vserver security trace filter delete
Delete a security trace entry
The vserver security trace filter delete command deletes a security trace filter entry. Prior to Data ONTAP 9.3, this feature was only supported for CIFS. In Data ONTAP 9.3 and later, this feature is supported for both NFS and CIFS.
NFS security trace filters are not supported for FlexGroup volumes, and will only be applied to the FlexVol volumes within the specified Vserver.
-vserver <vserver name> - Vserver
This parameter specifies the name of the Vserver on which the tracing filter entry that you want to delete is applied.
-index <integer> - Filter Index
This parameter specifies the index number for the filter that you want to delete. You can display a list of the filter index numbers by using the vserver security trace filter show command.
The following example deletes a security trace filter.
cluster1::> vserver security trace filter delete -vserver vs0 -index 1
