The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
network port broadcast-domain modify
PDF of this doc site
Creating your file...
Your file is ready
Modify a layer 2 broadcast domain
Modify a broadcast domain.
-ipspace <IPspace>
- IPspace Name-
The IPspace to which the broadcast domain belongs.
-broadcast-domain <Broadcast Domain>
- Layer 2 Broadcast Domain-
The name of the broadcast domain.
[-mtu <integer>]
- Configured MTU-
MTU of the broadcast domain.
The following example modifies the mtu attribute of broadcast domain "mgmt" in IPspace "Default" to 1500
cluster1::network port broadcast-domain*> modify -ipspace Default -broadcast-domain mgmt -mtu 1500
