cluster ha modify
Modify high-availability configuration of cluster management services
The cluster ha modify
command enables or disables cluster high availability in a two-node cluster. Enable high availability when performing some procedures, such as replacing hardware.
This command is required to enable high availability if the cluster only has two nodes. Do not run this command in a cluster that has three or more nodes. |
Cluster high availability for two-node clusters differs from the storage failover technology used between two nodes for storage high availability. |
[-configured {true|false}]
- HA Configured-
Use this parameter with the value
true
to enable high availability mode in the cluster. Use this parameter with the valuefalse
to disable high availability mode in the cluster.
The following example enables cluster high availability in a cluster.
cluster1::> cluster ha modify -configured true
