system controller slot module show
Display hotplug status of a module on the controller
The system controller slot module show
command displays hotplug status of a module on the controller. The command displays the following information about the PCIe modules:
Node
Slot
Module
Status
To display more details, use the -instance parameter.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-node {<nodename>|local}]
- Node-
Selects the PCIe modules that are present in the specified node.
[-slot <text>]
- Slot Number-
Selects the PCIe modules present in the specified slot or slot-subslot combination.
[-status <text>]
- Module Status-
Selects hotplug status for PCIe modules.
[-card <text>]
- Module Name-
Selects module name for PCIe modules.
The following example displays hotplug status of PCI modules found in the local node:
::> system controller slot module show -node local Node Slot Module Status -------------------- ----- ------------------------------ -------------------- localhost 1 IO_CARRIER_NIANTIC_NIC powered-on localhost 2 IO_4X_10GBT_INTL_NIC powered-on localhost 3 IO_4X_12Gb_PMC_SAS powered-on localhost 4 IO_4X_10GBE_16GFC_QLGC_CNA powered-on localhost 5 IO_4X_12Gb_PMC_SAS powered-on localhost 6 NVRAM10 hotplug-not-supported localhost 6-1 empty localhost 6-2 empty localhost 7 IO_4X_12Gb_PMC_SAS powered-on localhost 8 IO_4X_10GBT_INTL_NIC powered-on localhost 9 IO_4X_12Gb_PMC_SAS powered-on localhost 10 IO_4X_12Gb_PMC_SAS powered-on localhost 11 IO_4X_12Gb_PMC_SAS powered-on 13 entries were displayed. ::>
