ONTAP commands
system controller slot module show
Display hotplug status of a module on the controller
The system controller slot module show command displays hotplug status of a module on the controller. The command displays the following information about the PCIe modules:
  • Node
  • Slot
  • Module
  • Status
To display more details, use the -instance parameter.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-node {<nodename>|local}] - Node
Selects the PCIe modules that are present in the specified node.
[-slot <text>] - Slot Number
Selects the PCIe modules present in the specified slot or slot-subslot combination.
[-status <text>] - Module Status
Selects hotplug status for PCIe modules.
[-card <text>] - Module Name
Selects module name for PCIe modules.
The following example displays hotplug status of PCI modules found in the local node:
::> system controller slot module show -node local
Node                 Slot   Module                         Status
localhost            1      IO_CARRIER_NIANTIC_NIC         powered-on
localhost            2      IO_4X_10GBT_INTL_NIC           powered-on
localhost            3      IO_4X_12Gb_PMC_SAS             powered-on
localhost            4      IO_4X_10GBE_16GFC_QLGC_CNA     powered-on
localhost            5      IO_4X_12Gb_PMC_SAS             powered-on
localhost            6      NVRAM10                        hotplug-not-supported
localhost            6-1                                   empty
localhost            6-2                                   empty
localhost            7      IO_4X_12Gb_PMC_SAS             powered-on
localhost            8      IO_4X_10GBT_INTL_NIC           powered-on
localhost            9      IO_4X_12Gb_PMC_SAS             powered-on
localhost            10     IO_4X_12Gb_PMC_SAS             powered-on
localhost            11     IO_4X_12Gb_PMC_SAS             powered-on
13 entries were displayed.
