job private watch-progress
Watch the progress of a job
The job private watch-progress
command displays and periodically updates the progress of a private job. A private job is a job that is associated with a specific node and does not use cluster facilities. You can specify the frequency of the progress updates.
-node {<nodename>|local}
- Node (privilege: advanced)-
This specifies the node on which the job is running.
-id <integer>
- Job ID (privilege: advanced)-
This specifies the numeric ID of the job whose progress is to be monitored.
[-vserver <vserver name>]
- Owning Vserver (privilege: advanced)-
Use this parameter to specify the Vserver with which the paused private job is associated.
[-interval <integer>]
- Refresh Interval (seconds) (privilege: advanced)-
This optionally specifies, in seconds, the frequency of the updates.
The following example monitors the progress of the private job that has ID 127 on a node named node1. The progress is updated every 2 seconds.
cluster1::*> job private watch-progress -node node1 -id 127 -interval 2 Queued
