The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
storage raidlm policy modify
PDF of this doc site
Creating your file...
Your file is ready
Enable/Disable the policy
The storage raidlm policy modify
command is used to modify the available Raid Layout Manager policy.
-node <nodename>
- Node names (privilege: advanced)-
This parameter specifies the node on which this Raid Layout Manager policy is enabled.
-policy-name <text>
- Policy name for Raid-lm (privilege: advanced)-
This parameter specifies the Raid Layout Manager policy name.
-policy-type <text>
- Policy type for Raid-lm (privilege: advanced)-
This parameter specifies the Raid Layout Manager policy type.
[-is-enabled {true|false}]
- Is Policy Enabled? (privilege: advanced)-
This parameter specifies the value of the Raid Layout Manager policy to be modified. To see the list of Raid Layout Manager policy that can be modified, use the storage raidlm policy show command.
