vserver consistency-group volume create
Create a new volume in a consistency group
The vserver consistency-group volume create command creates new volumes in a consistency group.
-vserver <Vserver Name>- Vserver Name-
This parameter specifies the Vserver that contains the consistency group in which the volumes will be created.
-consistency-group <text>- Consistency Group-
This parameter specifies the consistency group in which the volumes will be created.
-parent-consistency-group <text>- Parent Consistency Group-
This parameter specifies the parent of the consistency group in which the volumes will be created.
-volume <volume name>- Volume-
This parameter specifies the name of the volume to be created in the consistency group. If the
-volume-countparameter is specified this field is treated as prefix. -size {<integer>[KB|MB|GB|TB|PB]}- Size-
This parameter specifies the size of each new volume that is to be created in the consistency group. If
-lunor-namespaceparameter is specified, this refers to the size of each LUN or namespace. [-volume-count <integer>]- Number of volumes-
This parameter specifies the number of new volumes to be created in the consistency group.
[-export-policy <export policy name>]- Volume Export Policy -
This parameter specifies the name of the export policy to be associated with the newly created volumes.
[-nas-path <junction path>]- Junction Path-
This parameter specifies the junction path for mounting the volumes.
[-nas-gid <integer>]- NAS Group ID-
This parameter specifies the NAS gid.
[-nas-junction-parent-volume <volume name>]- Junction Parent Volume Name-
This parameter specifis the NAS junction parent volume.
[-nas-security-style <security style>]- NAS Security Style-
This parameter specifis the NAS security style.
[-nas-uid <integer>]- NAS User ID-
This parameter specifies the NAS UID.
[-nas-unix-permissions <unix perm>]- NAS UNIX Permissions-
This parameter specifies the NAS UNIX permissions.
[-cifs-shares <Share>,…]- Volume CIFS Share Names-
This parameter specifies the name of the CIFS share to be created.
[-cifs-share-acl-user-or-group <text>]- CIFS User/Group Name-
This parameter specifies the acl user or group of the CIFS share for each volume in the new consistency group.
[-cifs-share-acl-win-unix-id <text>]- Windows SID or UNIXID-
This parameter specifies the acl windows or unix id of the CIFS share for each volume in the new consistency group.
[-cifs-share-acl-type {windows|unix-user|unix-group}]- CIFS User or Group Type-
This parameter specifies the acl type of the CIFS share for each volume in the new consistency group.
[-cifs-share-acl-permission <access rights>]- CIFS Access Type-
This parameter specifies the acl permission of the CIFS share for each volume in the new consistency group.
[-lun <text>]- LUN Name -
This parameter specifies the name of the LUN to be created in the consistency group. If the
-lun-countparameter is specified this field is treated as prefix. [-lun-count <integer>]- Number of LUNs-
This parameter specifies the number of new LUNs to be created in the consistency group.
[-lun-os-type <LUN Operating System Format>]- OS Type-
This parameter specifies the OS type for the new LUNs.
[-igroup <text>]- Igroup Name-
This parameter specifies the name of the initiator group.
[-namespace <text>]- Namespace Name -
This parameter specifies the name of the namespace to be created in the consistency group. If the
-namespace-countparameter is specified this field is treated as prefix. [-namespace-count <integer>]- Number of Namespaces-
This parameter specifies the number of new namespaces to be created in the consistency group.
[-namespace-os-type {aix|linux|vmware|windows}]- OS Type-
This parameter specifies the OS type for the new namespaces.
[-subsystem <text>]- Subsytem Name }-
This parameter specifies the name of the nvme subsystem.
+ The following command creates 2 new volumes in consistency group singleCG.
cluster1::> vserver consistency-group volume create -vserver vs0 -consistency-group singleCG -parent-consistency-group - -volume vol_singleCG -size 20M -volume-count 2
(vserver consistency-group volume create)
[Job 100] Job succeeded: Success
+ The following command creates 2 new volumes in consistency group singleCG with 2 new LUNs in each volume.
cluster1::> vserver consistency-group volume create -vserver vs0 -consistency-group singleCG -parent-consistency-group - -volume vol -size 20M -volume-count 2 -lun lun -lun-count 2 -lun-os-type linux -igroup ig1
[Job 101] Job succeeded: Success
+ The following command creates 2 new volumes in consistency group singleCG with 2 new nvme namespaces in each volume.
cluster1::> vserver consistency-group volume create -vserver vs0 -consistency-group singleCG -parent-consistency-group - -volume vol -size 20M -volume-count 2 -namespace ns -namespace-count 2 -namespace-os-type linux -subsystem ss1
[Job 102] Job succeeded: Success
+ The following command creates a new volume in consistency group singleCG with CIFS share alongiwth acl properties.
cluster1::> vserver consistency-group volume create -vserver vs0 -consistency-group singleCG -parent-consistency-group - -volume vol_singleCG -size 20M -volume-count 2 -cifs-shares share1 -cifs-share-acl-type windows -cifs-share-acl-user-or-group Everyone -cifs-share-acl-permission Read -nas-path "/vol"
[Job 103] Job succeeded: Success
