The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
vserver iscsi isns delete
PDF of this doc site
Creating your file...
Your file is ready
Remove the iSNS service for the Vserver
This command deletes the iSNS service for the Vserver.
-vserver <Vserver Name>
- Vserver Name-
Specifies the Vserver for the iSNS service that you want to delete.
cluster1::> vserver iscsi isns delete -vserver vs_1
Deletes the iSNS service for Vserver vs_1.
