storage path show-by-initiator
Display a list of paths to attached arrays from the initiator's perspective
The storage path show-by-initiator
command displays path based statistics. The output is similar to the storage path show command but the output is listed by initiator.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-node {<nodename>|local}]
- Controller name-
The name of the clustered node for which information is being displayed.
[-initiator <text>]
- Initiator Port-
Initiator port that the clustered node uses.
[-target-wwpn <text>]
- Target Port-
Target World Wide Port Name. Port on the storage array that is being used.
[-initiator-side-switch-port <text>]
- Initiator Side Switch Port-
Switch port connected to the clustered node.
[-target-side-switch-port <text>]
- Target Side Switch Port-
Switch port connected to the array.
[-array-name <array name>]
- Array Name-
Name of the storage array that is connected to the cluster.
[-tpgn <integer>]
- Target Port Group Number-
TPGN refers to the target port group to which the target port belongs. A target port group is a set of target ports which share the same LUN access characteristics and failover behaviors.
[-port-speed <text>]
- Port Speed-
Port Speed of the specified port.
[-path-io-kbps <integer>]
- Kbytes of I/O per second on Path (Rolling Average)-
Rolling average of I/O per second on the path.
[-path-iops <integer>]
- Number of IOPS on Path (Rolling Average)-
Rolling average of Kbytes of I/O per second on the path
[-initiator-io-kbps <integer>]
- Kbytes of I/O per second on Initiator (Rolling Average)-
Rolling average of I/O per second on the initiator port.
[-initiator-iops <integer>]
- Number of IOPS on Initiator (Rolling Average)-
Rolling average of Kbytes of I/O per second on the initiator port.
[-target-io-kbps <integer>]
- Kbytes of I/O per second to Target (Rolling Average)-
Rolling average of I/O per second on the target port.
[-target-iops <integer>]
- Number of IOPS to Target (Rolling Average)-
Rolling average of Kbytes of I/O per second on the target port.
vnv3070f20b::> storage path show-by-initiator Node: vnv3070f20b Initiator I/O Initiator Side Path I/O Target Side Target I/O Initiator (KB/s) Switch Port (KB/s) Switch Port (KB/s) Target Port Array Name --------- ------------- -------------------- ------------ -------------------- ------------ ---------------- ---------------- 0a 3 vnbr3850s4:4 3 vnbr3850s5:15 3 200600a0b819e16f IBM_1722_1 0 vnbr3850s5:12 0 50060e80004291c0 HITACHI_DF600F_1 0c 35 vnci9124s54:1-6 35 vnci9124s54:1-24 35 200700a0b819e16f IBM_1722_1 0 vnci9124s54:1-22 0 50060e80004291c2 HITACHI_DF600F_1 4 entries were displayed.
