volume snapshot compute-reclaimable
Calculate the reclaimable space if specified snapshots are deleted
The volume snapshot compute-reclaimable
command calculates the volume space that can be reclaimed if one or more specified Snapshot copies are deleted.
The command heavily uses system’s computational resources so it can reduce the performance for client requests and other system processes. Therefore, the queries that use queries that use query operators (*
, etc.), are disabled for this command. You should not specify more than three Snapshot copies per query. Snapshot copies must be specified as a comma-separated list with no spaces after the commas.
-vserver <vserver name>
- Vserver Name-
This specifies the Vserver on which the volume is located.
-volume <volume name>
- Volume Name-
This specifies the volume for which reclaimable space is to be calculated.
-snapshots <snapshot name>,…
- List of Snapshots-
This specifies one or more than one Snapshot copies that are to be considered for deletion. If you list more than one Snapshot copy, specify a comma-separated list with no spaces after the commas.
The following example calculates the space that can be reclaimed if the Snapshot copy named hourly.2008-01-10_1505 is deleted on a volume named vol3, which is a part of the Vserver named vs0:
cluster1::> volume snapshot compute-reclaimable -vserver vs0 -volume vol3 -snapshots hourly.2008-01-10_1505
