vserver nfs off
Disable the NFS service of a Vserver
The vserver nfs off
command disables NFS access on a Vserver. The Vserver must already exist.
-vserver <vserver name>
- Vserver-
This parameter specifies the Vserver on which you want to disable NFS access.
The following example disables NFS access on a Vserver named vs0.
cluster1::> vserver nfs off -vserver vs0
