vserver nfs show
Display the NFS configurations of Vservers
The vserver nfs show command displays information about NFS-enabled Vservers. The command output depends on the parameter or parameters specified with the command. If no parameters are specified, the command displays the following information about all NFS-enabled Vservers:
Vserver name
Whether general NFS access is enabled
Whether access to NFSv3 clients is enabled
Whether access to NFSv4 clients is enabled
Whether NFS access over UDP is enabled
Whether NFS access over TCP is enabled
List of default Windows users (detailed view only)
You can specify additional parameters to display only information that matches those parameters. For instance, to display information only about Vservers that enable access over TCP, enter the command with the -tcp-enable true parameter. + + All NFSv4.1 options apply to NFSv4.1 or later versions.
[-fields <fieldname>,…] -
If you specify the
-fieldsparameter, the command only displays the fields that you specify. - |
[-krb-opts ](privilege: advanced) -
If you specify the parameter for
-instance, the command shows detailed information about all NFS-enabled Vservers. Otherwise, if the-krb-optsparameter is specified, the command shows the following Kerberos-related information:-
Vserver name
Maximum number of RPCSEC_GSS authentication contexts
Time, in seconds, an RPCSEC_GSS context can remain idle before being deleted
Otherwise, if the
-fieldsparameter is specified, the command shows information about all of the NFS-enabled Vservers that you specify as a comma-delimited list. -
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all entries. [-vserver <vserver name>]- Vserver-
If you specify this parameter, the command displays information only about the specified NFS-enabled Vserver.
[-access {true|false}]- General NFS Access-
If you specify this parameter, the command displays information only about the NFS-enabled Vservers that have the specified general-access setting.
[-rpcsec-ctx-high <integer>]- RPC GSS Context Cache High Water Mark (privilege: advanced)-
If you specify this parameter, the command displays information only about NFS-enabled Vservers that have the specified maximum number of RPCSEC_GSS authentication contexts.
[-rpcsec-ctx-idle <integer>]- RPC GSS Context Idle (privilege: advanced)-
If you specify this parameter, the command displays information only about the NFS-enabled Vservers that have the specified timeout value for idle RPCSEC_GSS contexts.
[-v3 {enabled|disabled}]- NFS v3-
If you specify this parameter, the command displays information only about the NFS-enabled Vservers for which the
v3option matches the specified input. [-v4.0 {enabled|disabled}]- NFS v4.0-
If you specify this parameter, the command displays information only about NFS-enabled Vservers for which the
v4.0option matches the specified input. [-udp {enabled|disabled}]- UDP Protocol-
If you specify this parameter, the command displays information only about the NFS-enabled Vservers that have the specified NFS-over-UDP access setting.
[-tcp {enabled|disabled}]- TCP Protocol-
If you specify this parameter, the command displays information only about the NFS-enabled Vservers that have the specified NFS-over-TCP setting.
[-default-win-user <text>]- Default Windows User-
If you specify this parameter, the command displays information only about the NFS-enabled Vservers that have the specified list of default Windows users.
[-enable-ejukebox {true|false}]- Enable NFSv3 EJUKEBOX error (privilege: advanced)-
enable-ejukeboxoption matches the specified input. [-v3-require-read-attributes {true|false}]- Require All NFSv3 Reads to Return Read Attributes (privilege: advanced)-
If you specify this parameter, the command displays information only about the NFS-enabled Vservers for which NFSv3 read operations are required or not required to return read attributes.
[-v3-fsid-change {enabled|disabled}]- Show Change in FSID as NFSv3 Clients Traverse Filesystems (privilege: advanced)-
If you specify this parameter, the command displays information about changes in file system identifiers (FSIDs) as NFSv3 clients traverse file systems.
[-v3-connection-drop {enabled|disabled}]- Enable the Dropping of a Connection When an NFSv3 Request is Dropped (privilege: advanced)-
v3-connection-dropoption matches the specified input. [-ntfs-unix-security-ops {fail|ignore|use_export_policy}]- Vserver NTFS Unix Security Options (privilege: advanced)-
If you specify this parameter, the command displays information only about the NFS-enabled Vservers for which the NTFS-UNIX security setting matches the specified input.
[-chown-mode {restricted|unrestricted|use_export_policy}]- Vserver Change Ownership Mode (privilege: advanced)-
If you specify this parameter, the command displays information only about the NFS-enabled Vservers for which the chown-mode setting matches the specified input.
[-trace-enabled {true|false}]- NFS Response Trace Enabled (privilege: advanced)-
trace-enabledoption matches the specified input. [-trigger <integer>]- NFS Response Trigger (in secs) (privilege: advanced)-
If you specify this parameter, the command displays information only about the NFS-enabled Vservers with the specified NFS response trigger time.
[-udp-max-xfer-size <integer>]- UDP Maximum Transfer Size (bytes) (privilege: advanced)-
If you specify this parameter, the command displays information only about the NFS-enabled Vservers with the specified UDP maximum transfer size. The range is 8192 to 57344.
[-tcp-max-xfer-size <integer>]- TCP Maximum Transfer Size (bytes) (privilege: advanced)-
If you specify this parameter, the command displays information only about the NFS-enabled Vservers with the specified TCP maximum transfer size. The range is 8192 to 1048576.
[-v4.0-acl {enabled|disabled}]- NFSv4.0 ACL Support-
v4.0-acloption matches the specified input. [-v4.0-read-delegation {enabled|disabled}]- NFSv4.0 Read Delegation Support-
v4.0-read-delegationoption matches the specified input. [-v4.0-write-delegation {enabled|disabled}]- NFSv4.0 Write Delegation Support-
v4.0-write-delegationoption matches the specified input. [-v4-fsid-change {enabled|disabled}]- Show Change in FSID as NFSv4 Clients Traverse Filesystems (privilege: advanced)-
If you specify this parameter, the command displays information only about the NFS-enabled Vservers for which the showing of NFSv4 file system identifier (FSID) changes has been enabled or disabled.
[-v4.0-referrals {enabled|disabled}]- NFSv4.0 Referral Support (privilege: advanced)-
v4.0-referralsoption matches the specified input. [-v4-id-domain <nfs domain>]- NFSv4 ID Mapping Domain-
If you specify this parameter, the command displays information only about the NFS-enabled Vservers having the specified domain name.
[-v4-validate-symlinkdata {enabled|disabled}]- NFSv4 Validate UTF-8 Encoding of Symbolic Link Data (privilege: advanced)-
If you specify this parameter, the command displays information only about the NFS-enabled Vservers for which validation of UTF-8 encoding of symbolic link data has been enabled or disabled.
[-v4-lease-seconds <integer>]- NFSv4 Lease Timeout Value (in secs) (privilege: advanced)-
If you specify this parameter, it displays the locking lease period. It is expressed in seconds. Clients that have been inactive for a period equal or longer to the lease period may lose all their locking state on a node.
[-v4-grace-seconds <integer>]- NFSv4 Grace Timeout Value (in secs)-
If you specify this parameter, it displays the grace period for clients to reclaim file locks after a server failure. The grace period is expressed in seconds.
[-v4-acl-preserve {enabled|disabled}]- Preserves and Modifies NFSv4 ACL (and NTFS File Permissions in Unified Security Style)-
v4-acl-preserveoption matches the specified input. [-v4.1 {enabled|disabled}]- NFSv4.1 Minor Version Support-
v4.1option matches the specified input. [-rquota {enabled|disabled}]- Rquota Enable-
rquotaoption matches the specified input. [-v4.1-implementation-domain <nfs domain>]- NFSv4.1 Implementation ID Domain (privilege: advanced)-
v4.1-implementation-domainoption matches the specified input. [-v4.1-implementation-name <text>]- NFSv4.1 Implementation ID Name (privilege: advanced)-
v4.1-implementation-nameoption matches the specified input. [-v4.1-implementation-date <Date>]- NFSv4.1 Implementation ID Date (privilege: advanced)-
v4.1-implementation-dateoption matches the specified input. [-v4.1-pnfs {enabled|disabled}]- NFSv4.1 Parallel NFS Support-
v4.1-pnfsoption matches the specified input. [-v4.1-referrals {enabled|disabled}]- NFSv4.1 Referral Support (privilege: advanced)-
v4.1-referralsoption matches the specified input. [-v4.1-acl {enabled|disabled}]- NFSv4.1 ACL Support-
v4.1-acloption matches the specified input. [-vstorage {enabled|disabled}]- NFS vStorage Support-
vstorageoption matches the specified input. [-v4-numeric-ids {enabled|disabled}]- NFSv4 Support for Numeric Owner IDs-
v4-numeric-idsoption matches the specified input. [-default-win-group <text>]- Default Windows Group-
If you specify this parameter, the command displays information only about the NFS-enabled Vservers that have the specified list of default Windows groups.
[-v4.1-read-delegation {enabled|disabled}]- NFSv4.1 Read Delegation Support-
v4.1-read-delegationoption matches the specified input. [-v4.1-write-delegation {enabled|disabled}]- NFSv4.1 Write Delegation Support-
v4.1-write-delegationoption matches the specified input. [-v4.x-session-num-slots <integer>]- Number of Slots in the NFSv4.x Session slot tables (privilege: advanced)-
If you specify this parameter, this command displays information only about the NFS-enabled Vservers for which the
v4.x-session-num-slotsoption matches the specified input. The range is 1 to 2000. [-v4.x-session-slot-reply-cache-size <integer>]- Size of the Reply that will be Cached in Each NFSv4.x Session Slot (in bytes) (privilege: advanced)-
v4.x-session-slot-reply-cache-sizeoption matches the specified input. The cache size is expressed in bytes. The range is 512 to 4096. [-v4-acl-max-aces <integer>]- Maximum Number of ACEs per ACL (privilege: advanced)-
v4-acl-max-acesoption matches the specified input. [-mount-rootonly {enabled|disabled}]- NFS Mount Root Only-
mount-rootonlyoption matches the specified input. [-nfs-rootonly {enabled|disabled}]- NFS Root Only-
nfs-rootonlyoption matches the specified input. [-auth-sys-extended-groups {enabled|disabled}]- AUTH_SYS Extended Groups Enabled (privilege: advanced)-
auth-sys-extended-groupsoption matches the specified input. [-extended-groups-limit <integer>]- AUTH_SYS and RPCSEC_GSS Auxillary Groups Limit (privilege: advanced)-
If you specify this parameter, the command displays information about the NFS-enabled Vservers for which the
extended-groups-limitoption matches the specified input. The range is 32 to 1024. [-validate-qtree-export {enabled|disabled}]- Validation of Qtree IDs for Qtree File Operations (privilege: advanced)-
validate-qtree-exportoption matches the specified input. [-mountd-port <integer>]- NFS Mount Daemon Port (privilege: advanced)-
mountd-portoption matches the specified input. [-nlm-port <integer>]- Network Lock Manager Port (privilege: advanced)-
nlm-portoption matches the specified input. [-nsm-port <integer>]- Network Status Monitor Port (privilege: advanced)-
nsm-portoption matches the specified input. [-rquotad-port <integer>]- NFS Quota Daemon Port (privilege: advanced)-
rquotad-portoption matches the specified input. [-permitted-enc-types <NFS Kerberos Encryption Type>,…]- Permitted Kerberos Encryption Types-
permitted-enc-typesoption matches any of the following : des, des3, aes-128, aes-256. [-showmount {enabled|disabled}]- Showmount Enabled-
If you specify this parameter, the command displays information only about the NFS-enabled Vserver's for which the
showmountoption matches the specified input. [-name-service-lookup-protocol {TCP|UDP}]- Set the Protocol Used for Name Services Lookups for Exports-
-name-service-lookup-protocolmatches the parameter. [-map-unknown-uid-to-default-windows-user {enable|disable}]- Map Unknown UID to Default Windows User (privilege: advanced)-
-map-unknown-uid-to-default-windows-useris enabled or disabled. [-netgroup-dns-domain-search {enabled|disabled}]- DNS Domain Search Enabled During Netgroup Lookup (privilege: advanced)-
-netgroup-dns-domain-searchis enabled or disabled. [-netgroup-trust-any-ns-switch-no-match {enabled|disabled}]- Trust No-Match Result from Any Name Service Switch Source During Netgroup Lookup (privilege: advanced)-
-netgroup-trust-any-ns-switch-no-matchis enabled or disabled. [-ntacl-display-permissive-perms {enabled|disabled}]- Display maximum NT ACL Permissions to NFS Client (privilege: advanced)-
-ntacl-display-permissive-permsmatches the parameter. [-v3-ms-dos-client {enabled|disabled}]- NFSv3 MS-DOS Client Support-
If you specify this parameter, the command displays information only about NFS-enabled Vservers for which NFSv3 MS-DOS client support is enabled or disabled.
[-ignore-nt-acl-for-root {enabled|disabled}]- Ignore the NT ACL Check for NFS User 'root' (privilege: advanced)-
-ignore-nt-acl-for-rootis enabled or disabled. [-cached-cred-positive-ttl <integer>]- Time To Live Value (in msecs) of a Positive Cached Credential (privilege: advanced)-
If you specify this parameter, the command displays information about the NFS-enabled Vservers time to live value of the positive cached credentials.
[-cached-cred-negative-ttl <integer>]- Time To Live Value (in msecs) of a Negative Cached Credential (privilege: advanced)-
If you specify this parameter, the command displays information about the NFS-enabled Vservers time to live value of the negative cached credentials.
[-skip-root-owner-write-perm-check {enabled|disabled}]- Skip Permission Check for NFS Write Calls from Root/Owner (privilege: advanced)-
-skip-root-owner-write-perm-checkis enabled or disabled. [-v3-64bit-identifiers {enabled|disabled}]- Use 64 Bits for NFSv3 FSIDs and File IDs (privilege: advanced)-
-v3-64bit-identifiersis enabled or disabled. [-v4-inherited-acl-preserve {enabled|disabled}]- Ignore Client Specified Mode Bits and Preserve Inherited NFSv4 ACL When Creating New Files or Directories (privilege: advanced)-
-v4-inherited-acl-preservematches the specified input. [-v3-search-unconverted-filename {enabled|disabled}]- Fallback to Unconverted Filename Search (privilege: advanced)-
-v3-search-unconverted-filenamematches the specified input. [-file-session-io-grouping-count <integer>]- I/O Count to Be Grouped as a Session (privilege: advanced)-
If you specify this parameter, the command displays information about the NFS-enabled SVMs for which the
-file-session-io-grouping-countmatches the specified input. [-file-session-io-grouping-duration <integer>]- Duration for I/O to Be Grouped as a Session (Secs) (privilege: advanced)-
-file-session-io-grouping-durationmatches the specified input. [-checksum-for-replay-cache {enabled|disabled}]- Enable or disable Checksum for Replay-Cache (privilege: advanced)-
-checksum-for-replay-cachematches the specified input. [-cached-cred-harvest-timeout <integer>]- Harvest timeout (in msecs) for a Cached Credential (privilege: advanced)-
If you specify this parameter, the command displays information about the NFS-enabled Vservers harvest timeout for cached credentials.
[-idle-connection-timeout <integer>]- Idle Connection Timeout Value (in seconds)-
If you specify this parameter, the command displays information about the NFS-enabled Vservers idle connections timeout
[-allow-idle-connection-timeout {enabled|disabled}]- Are Idle NFS Connections Supported-
-allow-idle-connection-timeoutoption matches the specified input. [-v3-hide-snapshot {enabled|disabled}]- Hide Snapshot Directory under NFSv3 Mount Point-
-v3-hide-snapshotmatches the specified input. [-showmount-rootonly {enabled|disabled}]- Provide Root Path as Showmount State-
-showmount-rootonlymatches the specified input. [-v4-64bit-identifiers {enabled|disabled}]- Use 64 Bits for NFSv4.x FSIDs and File IDs (privilege: advanced)-
-v4-64bit-identifiersis enabled or disabled. [-v4.2-seclabel {enabled|disabled}]- NFSV4.2 Security Label Support (privilege: advanced)-
v4.2-seclabeloption matches the specified input. [-rdma {enabled|disabled}]- RDMA Protocol-
If you specify this parameter, the command displays information only about the NFS-enabled Vservers that have the specified NFS-over-RDMA setting.
[-v4.1-trunking {enabled|disabled}]- NFSV4.1 Trunking Support-
v4.1-trunkingoption matches the specified input. [-v4.2-sparsefile-ops {enabled|disabled}]- NFSV4.2 Sparse Files Ops Support (privilege: advanced)-
v4.2-sparsefile-opsoption matches the specified input. [-v4.2-xattrs {enabled|disabled}]- NFSV4.2 Extended Attributes Support-
v4.2-xattrsoption matches the specified input. [-v4.1-sequence-admin-revoked {enabled|disabled}]- NFSV4 Admin Revoked Support (privilege: advanced)-
If you specify this parameter, the command only displays information about the NFS-enabled Vservers for which the
v4.1-sequence-admin-revokedoption matches the specified input. [-v4-acl-compliance {enabled|disabled}]- NFSV4 ACL Compliance Support (privilege: advanced)-
If you specify this parameter, the command only displays information about the NFS-enabled Vservers where NFSv41 acl compliance is enabled or disabled.
The following example displays information about all NFS-enabled Vservers:
cluster1::> vserver nfs show
General Default
Vserver Access v3 v4 v4.1 UDP TCP Windows User
vs0 true enabled disabled disabled enabled enabled -
vs1 true enabled disabled disabled enabled enabled -
2 entries were displayed.
The following example displays Kerberos-related information about all NFS-enabled Vservers:
cluster1::*> vserver nfs show -krb-opts Vserver Context High Context Idle -------------- ------------ ------------ vs0 30 30 vs1 30 30 2 entries were displayed.
