ONTAP commands
vserver add-protocols
Add protocols to the Vserver
The vserver add-protocols command adds given protocols to a specified Vserver.
-vserver <vserver> - Vserver
This specifies the Vserver that is to be modified.
-protocols {nfs|cifs|fcp|iscsi|ndmp|nvme|s3} - Protocols
This parameter specifies the list of protocols to be allowed to run on the Vserver. Possible values include nfs , cifs , fcp , iscsi , ndmp and nvme .
The following example shows adding protocol 'cifs' to a vserver named vs0.example.com.
cluster1::> vserver add-protocols -vserver vs0.example.com -protocols cifs
