vserver name-mapping show
Display name mappings
The vserver name-mapping show
command displays information about name mappings. The command output depends on the parameter or parameters specified with the command. If you do not specify any parameters, the command displays the following information about all name mappings:
Vserver name
Direction of the mapping (krb-unix for Kerberos-to-UNIX, win-unix for Windows-to-UNIX, or unix-win for UNIX-to-Windows)
Position of the mapping in the priority list
Pattern to be matched
Replacement pattern
You can specify additional parameters to display only information that matches those parameters. For instance, to display information only about Kerberos-to-UNIX name mappings, run the command with the -direction krb-unix
parameter.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-vserver <vserver name>]
- Vserver-
If you specify this parameter, the command displays information only about the name mapping or mappings that match the specified Vserver.
[-direction {krb-unix|win-unix|unix-win|s3-unix|s3-win}]
- Direction-
If you specify this parameter, the command displays information only about the name mapping or mappings that have the specified mapping direction.
[-position <integer>]
- Position-
If you specify this parameter, the command displays information only about the name mapping that has the specified position in the priority list.
[-pattern <text>]
- Pattern-
If you specify this parameter, the command displays information only about the name mapping or mappings that use the specified matching pattern. The pattern can be up to 256 characters in length. Refer to the command description section for details.
[-replacement <text>]
- Replacement-
If you specify this parameter, the command displays information only about the name mapping or mappings that use the specified replacement pattern.
[-address <IP Address/Mask>]
- IP Address with Subnet Mask-
If you specify this parameter, the command displays information only about the name mapping or mappings that use the specified IP address.
[-hostname <text>]
- Hostname-
If you specify this parameter, the command displays information only about the name mapping or mappings that use the specified hostname.
The following example displays information about all name mappings:
cluster1::> vserver name-mapping show Vserver: vs1 Direction: win-unix Position Hostname IP Address/Mask -------- ---------------- ---------------- 1 google.com - Pattern: EXAMPLE\\administrator Replacement: nobody 2 - 10.238.2.34/32 Pattern: EXAMPLE\\(.+) Replacement: \_1
