cluster peer offer cancel
Cancel the outstanding offer to authenticate with a peer cluster
The cluster peer offer cancel
command cancels an outstanding offer to authenticate with a potentially peered cluster. After the command completes, the given cluster can no longer establish authentication using the given authentication offer.
-cluster <text>
- Peer Cluster Name-
Use this parameter to specify which offer should be cancelled, by specifying the name of the cluster to which the offer is extended.
The following example cancels the authentication offer to cluster2.
cluster1::> cluster peer offer cancel -cluster cluster2
