system ha interconnect port sharing modify
The system ha interconnect port sharing modify command sets the state of port sharing for the specified node.
-node <nodename>- Node (privilege: advanced)-
This parameter specifies the node on which to modify port sharing.
[-enabled {true|false}]- Enabled (privilege: advanced)-
Set this parameter to enable/disable port sharing.
The following example modifies the HA interconnect device port sharing to enabled:
cluster1::*> system ha interconnect port sharing modify -node node1 -enabled true cluster1::*> system ha interconnect port sharing show Node Enabled -------------- ------- node1 true node2 false
