ONTAP commands
system ha interconnect port sharing modify
The system ha interconnect port sharing modify command sets the state of port sharing for the specified node.
-node <nodename> - Node (privilege: advanced)
This parameter specifies the node on which to modify port sharing.
[-enabled {true|false}] - Enabled (privilege: advanced)
Set this parameter to enable/disable port sharing.
The following example modifies the HA interconnect device port sharing to enabled:
cluster1::*> system ha interconnect port sharing modify -node node1 -enabled true
cluster1::*> system ha interconnect port sharing show
Node            Enabled
node1           true
node2           false
