lun import throttle
Modify the max throughput limit for the specified import relationship
This command throttles the speed of the import for a given LUN by specifying a maximum throughput limit on the import.
-vserver <Vserver Name>
- Vserver Name (privilege: advanced)-
Specifies the Vserver that contains the LUN to which data from the foreign disk is imported.
-path <path>
- LUN Path (privilege: advanced)-
Specifies the path of the LUN to which data from the foreign disk is imported. Examples of correct LUN paths are
/vol/vol1/lun1
and/vol/vol1/qtree1/lun1
. -max-throughput-limit {<integer>[KB|MB|GB|TB|PB]}
- Maximum Throughput Limit (per sec) (privilege: advanced)-
Specifies the maximum amount of throughput to be allocated for processing import requests on the bound LUN. At the time of creation, the default is zero. A value of zero implies that import traffic is processed by the system at best effort rate along with on-going user I/O. A non-zero value indicates that import will be throttled at a rate which is at most the maximum throughput limit set.
cluster1::*> lun import throttle -vserver vs1 -path /vol/vol1/lun1 -max-throughput-limit 3M
The above example limits the import speed for the bound LUN with path /vol/vol1/lun1 to a maximum of 3MB/s.
