network interface rename
Rename a logical interface
Use the network interface rename
command to change the name of an existing logical interface.
-vserver <vserver>
- Vserver Name-
Use this parameter to specify the Vserver on which the logical interface to rename is located.
-lif <lif-name>
- Logical Interface Name-
Use this parameter to specify the name of the logical interface to rename.
-newname <text>
- The new name for the interface-
Use this parameter to specify the new name of the logical interface. For iSCSI and FC LIFs, the name cannot be more than 254 characters.
The following example renames a cluster logical interface named cluslif1 to cluslif4 on a Vserver named vs0.
cluster1::> network interface rename -vserver vs0 -lif cluslif1 -newname cluslif4
