storage aggregate show-space
Display details of space utilization within an aggregate.
The storage aggregate show-space command displays information about space utilization within aggregates and any attached external capacity tier. The command output breaks down space usage in the specified aggregate by feature. If no parameters are specified, the command displays this information about all aggregates. Note that used percentage for an external capacity tier will be non-zero only if a size limit was set for that aggregate's attached tier.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-aggregate-name <aggregate name>]- Aggregate-
If this parameter is specified, the command displays information only about the specified aggregates.
[-bin-num <integer>]- Bin Number-
If this parameter is specified, the command displays information only about the aggregates whose bin number for the storage tier matches the specified value. Typically, bin 0 refers to the performance tier or active file system and bin numbers greater than 0 refer to the external capacity tiers attached to the aggregate.
[-tier-name <text>]- Tier Name For Show Command-
If this parameter is specified, the command displays information only about the aggregates whose attached storage tier name matches the specified value.
[-aggregate <aggregate name>]- Aggregate Display Name-
If this parameter is specified, the command displays information only about space used in the specified aggregate or aggregates.
[-aggregate-uuid <UUID>]- Uuid of the Aggregate-
If this parameter is specified, the command displays information only about the aggregates whose UUID matches the specified value.
[-volume-footprints {<integer>[KB|MB|GB|TB|PB]}]- Volume Footprints-
If this parameter is specified, the command displays information only about the aggregate or aggregates that have the specified amount of space in use by volume footprints. A volume's footprint is the overall amount of space that a volume occupies in the aggregate, including the volume metadata and data.
[-volume-footprints-percent <percent_no_limit>]- Volume Footprints Percent-
If this parameter is specified, the command displays information only about the aggregate or aggregates whose volume footprints occupy the specified percentage of space.
[-snap-size-total {<integer>[KB|MB|GB|TB|PB]}]- Total Space for Snapshot Copies in Bytes-
If this parameter is specified, the command displays information only about the aggregate or aggregates that have the specified amount of space in use by aggregate Snapshot copies. This field includes the space that is reserved for Snapshot copies and is not available to volumes or aggregate data and metadata. It is set to 0 by default.
[-percent-snapshot-space <percent>]- Space Reserved for Snapshot Copies-
If this parameter is specified, the command displays information only about the aggregate or aggregates that have the specified percentage of space in use by aggregate Snapshot copies.
[-aggregate-metadata {<integer>[KB|MB|GB|TB|PB]}]- Aggregate Metadata-
If this parameter is specified, the command displays information only about the aggregate or aggregates that have the specified amount of space in use by aggregate metadata.
[-aggregate-metadata-percent <percent_no_limit>]- Aggregate Metadata Percent-
If this parameter is specified, the command displays information only about the aggregate or aggregates that have the specified percentage of space in use by aggregate metadata.
[-used-including-snapshot-reserve {<integer>[KB|MB|GB|TB|PB]}]- Total Used-
If this parameter is specified, the command displays information only about the aggregate or aggregates that have the specified amount of space in use in the aggregate.
It is important to note that this parameter treats the entire Snapshot reserve as used space since it is not available for volumes.
[-used-including-snapshot-reserve-percent <percent_no_limit>]- Total Used Percent-
If this parameter is specified, the command displays information only about the aggregate or aggregates that have the specified percentage of space in use in the aggregate and its Snapshot reserve.
[-aggregate-size {<integer>[KB|MB|GB|TB|PB]}]- Size-
If this parameter is specified, the command displays information only about the aggregate or aggregates that have the specified size.
[-snapshot-reserve-unusable {<integer>[KB|MB|GB|TB|PB]}]- Snapshot Reserve Unusable-
If this parameter is specified, the command displays information only about the aggregate or aggregates that have the specified amount of space reserved but unusable in the volume.
Snapshot reserve can be diminished under certain conditions to accommodate volume metadata. Creating space in the aggregate will make this space available.
[-snapshot-reserve-unusable-percent <percent_no_limit>]- Snapshot Reserve Unusable Percent-
If this parameter is specified, the command displays information only about the aggregate or aggregates that have the specified percentage of space reserved but unusable.
[-physical-used {<integer>[KB|MB|GB|TB|PB]}]- Total Physical Used Size-
If this parameter is specified, the command displays information only about the aggregate or aggregates that have the specified amount of physical space in use by the aggregate.
This differs from
total-usedspace by the space that is guaranteed for future writes. The value includes blocks in use by Snapshot copies. [-physical-used-percent <percent_no_limit>]- Physical Used Percentage-
If this parameter is specified, the command displays information only about the aggregate or aggregates that have the specified percentage of physical space in use in the aggregates.
[-performance-tier-inactive-user-data {<integer>[KB|MB|GB|TB|PB]}]- Performance Tier Inactive User Data-
If this parameter is specified, the command displays information only about the aggregates whose amount of inactive user data in the performance tier matches the specified value. The inactive user data can be tiered out to a capacity tier if the aggregate is a FabricPool.
[-performance-tier-inactive-user-data-percent <percent>]- Performance Tier Inactive User Data Percent-
If this parameter is specified, the command displays information only about the aggregates whose percentage of inactive user data in the performance tier matches the specified value.
[-cross-volume-dedupe-metadata {<integer>[KB|MB|GB|TB|PB]}]- Aggregate Dedupe Metadata-
If this parameter is specified, the command displays information only about the aggregate or aggregates that have the specified amount of space in use by cross volume deduplication metadata.
[-cross-volume-dedupe-metadata-percent <percent_no_limit>]- Aggregate Dedupe Metadata Percent-
If this parameter is specified, the command displays information only about the aggregate or aggregates that have the specified percentage of space in use by cross volume deduplication metadata.
[-cross-volume-dedupe-temp-metadata {<integer>[KB|MB|GB|TB|PB]}]- Aggregate Dedupe Temporary Metadata-
If this parameter is specified, the command displays information only about the aggregate or aggregates that have the specified amount of space in use by cross volume deduplication temporary metadata.
[-cross-volume-dedupe-temp-metadata-percent <percent_no_limit>]- Aggregate Dedupe Temporary Metadata Percent-
If this parameter is specified, the command displays information only about the aggregate or aggregates that have the specified percentage of space in use by cross volume deduplication temporary metadata.
[-total-provisioned-space {<integer>[KB|MB|GB|TB|PB]}]- Total Space Provisioned inside Aggregate-
If this parameter is specified, the command displays information about the total provisioned space across all the volumes in the aggr.
[-total-provisioned-space-percent <percent_no_limit>]- Percentage Space Provisioned inside Aggregate-
If this parameter is specified, the command displays information about the percentage of total provisioned space across all the volumes against aggr's size.
[-object-store-physical-used {<integer>[KB|MB|GB|TB|PB]}]- Total Object Store Physical Used Size-
If this parameter is specified, the command displays information only about the aggregates whose physical space use in the attached object store matches the specified value.
[-object-store-physical-used-percent <percent_no_limit>]- Object Store Physical Used Percentage-
If this parameter is specified, the command displays information only about aggregates whose physical space in use in the attached object store as a percentage of the license limit matches the specified value.
[-object-store-referenced-capacity {<integer>[KB|MB|GB|TB|PB]}]- Total Object Store Logical Referenced Capacity-
If this parameter is specified, the command displays information only about the aggregates whose logical reference capacity space in use in the attached object store matches the specified value.
[-object-store-referenced-capacity-percent <percent_no_limit>]- Object Store Logical Referenced Capacity Percentage-
If this parameter is specified, the command displays information only about aggregates whose logical reference capacity space in use in the attached object store as a percentage of the license limit matches the specified value.
[-object-store-metadata {<integer>[KB|MB|GB|TB|PB]}]- (DEPRECATED)-Object Store Metadata-
This parameter is deprecated in Data ONTAP 9.10.1 and later. If this parameter is specified, the command displays information only about the aggregates whose metadata space in use in the attached object store matches the specified value.
[-object-store-metadata-percent <percent_no_limit>]- (DEPRECATED)-Object Store Metadata Percent-
This parameter is deprecated in Data ONTAP 9.10.1 and later. If this parameter is specified, the command displays information only about aggregates whose metadata space in use in the attached object store as a percentage of the license limit matches the specified value.
[-object-store-unreclaimed-space {<integer>[KB|MB|GB|TB|PB]}]- (DEPRECATED)-Total Unreclaimed Space-
This parameter is deprecated in Data ONTAP 9.10.1 and later. If this parameter is specified, the command displays information only about the aggregates whose unreclaimed space in use in the attached object store matches the specified value.
[-object-store-unreclaimed-space-percent <percent_no_limit>]- (DEPRECATED)-Object Store Unreclaimed Space Percentage-
This parameter is deprecated in Data ONTAP 9.10.1 and later. If this parameter is specified, the command displays information only about aggregates whose unreclaimed space in use in the attached object store as a percentage of the license limit matches the specified value.
[-object-store-size {<integer>[KB|MB|GB|TB|PB]}]- Object Store Size-
If this parameter is specified, the command displays information only about the aggregates whose attached object store size limit matches the specified value.
[-object-store-sis-space-saved {<integer>[KB|MB|GB|TB|PB]}]- Object Store Space Saved by Storage Efficiency-
If this parameter is specified, the command displays information only about the aggregates whose amount of space saved by storage efficiency matches the specified value.
[-object-store-sis-space-saved-percent <percent_no_limit>]- Object Store Space Saved by Storage Efficiency Percentage-
If this parameter is specified, the command displays information only about the aggregates whose percentage of space saved by storage efficiency matches the specified value.
[-object-store-logical-used {<integer>[KB|MB|GB|TB|PB]}]- Total Object Store Logical Used Size-
If this parameter is specified, the command displays information only about the aggregates whose logical space use in the attached object store matches the specified value.
[-object-store-logical-used-percent <percent_no_limit>]- Object Store Logical Used Percentage-
If this parameter is specified, the command displays information only about aggregates whose logical space in use in the attached object store as a percentage of the license limit matches the specified value.
[-object-store-logical-unreferenced-capacity {<integer>[KB|MB|GB|TB|PB]}]- Object Store Logical Unreferenced Capacity-
If this parameter is specified, the command displays information only about the aggregates whose logical unreferenced capacity in use in the attached object store matches the specified value.
[-object-store-logical-unreferenced-capacity-percent <percent_no_limit>]- Object Store Logical Unreferenced Percentage-
This parameter is deprecated in Data ONTAP 9.10.1 and later. If this parameter is specified, the command displays information only about aggregates whose logical unreferenced capacity in use in the attached object store as a percentage of the license limit matches the specified value.
The following example displays information about all aggregates:
cluster1::> storage aggregate show-space
Aggregate : aggr0
Feature Used Used%
Volume Footprints 5.75GB 91%
Aggregate Metadata 380KB 0%
Snapshot Reserve 325.3MB 5%
Total Used 6.07GB 96%
Total Physical Used 221.9MB 3%
Aggregate : aggr1
Feature Used Used%
Volume Footprints 2.03GB 33%
Aggregate Metadata 304KB 0%
Total Used 2.03GB 33%
Total Physical Used 2.23MB 0%
2 entries were displayed.
The following example displays information about all the aggregates in a system including the ones that have an object store attached to them.
cluster-1::> storage aggregate show-space
Aggregate : aggr0
Feature Used Used%
Volume Footprints 2.87GB 90%
Aggregate Metadata 328KB 0%
Snapshot Reserve 162.6MB 5%
Total Used 3.03GB 95%
Total Physical Used 2.08GB 65%
Aggregate : aggr1
Performance Tier
Feature Used Used%
Volume Footprints 1.25GB 13%
Aggregate Metadata 540KB 0%
Snapshot Reserve 0B 0%
Total Used 1.25GB 13%
Total Physical Used 1.23GB 13%
Aggregate : aggr1
Object Store: my-store
Feature Used Used%
Referenced Capacity 811.2MB 0%
Metadata 0B 0%
Unreclaimed Space 0B 0%
Space Saved by Storage Efficiency 0B 0%
Total Physical Used 811.2MB 0%
